Ana içeriğe geç
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
Karcher power washer don't work
Power washer has no high pressure water come out of it. I've watched all the videos I can find on YouTube and I still haven't figured out what's wrong with it. I've looked at the valves. In fact I have 2 of these power washers that don't work that I have had a part and looked at the valves and I'm not seeing anything wrong with any of them. Do you have any idea what might be wrong with these two power washers are there any other video other than YouTube that you can recommend.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@a2221 could be a pump issues as well as possible clogged filters etc. Common Karcher low pressure isssues are related to :
Problems That Cause Low Water Pressure
A. Water Supply
A problem with the water supply. Use cold water only.
B. Worn Nozzle
A worn nozzle on the spray gun.
C. Water Inlet Filter
A clogged water inlet filter (20).
D. Bypass Valve
Worn O-rings on the bypass valve (19), or a bypass valve hanging up.
E. High-Pressure Check Valve
High-pressure valve (43-46) fails to function properly.
F. Low Pressure Check Valve
Low-pressure valve (24-27) fails to function properly.
G Water Leaks – See Section 2 / Water Leaks
Water leaks
H. Pump is Cycling – See Section 4 / Detergent Delivery Failure
Nozzle insert (32) is damaged and must be replaced.It will all depend on which model you have and what you have checked.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I am having problems with my karcher washer not making pressure. I tried to remove the pump discharge nozzle insert to clean it. It would not come out, I ended up damaging it and drilling it out. I am wondering if this is the problem. Can someone please explain to me the function of the nozzle insert so I can understand why the pump does not make pressure without it? Makes no sense to me.
Puan 0
Yorum Ekle
Yanıtını ekle
2221 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 33
Son 30 gün: 86
Her zaman: 26,975
