Ana içeriğe geç
E32 7 Serisi ve E34 5 Serisi'ne benzer kutu gibi 80'li yıllar tarzını taşıyan son 3 Serisi olan ikinci nesil (E30) BMW 3 Serisi.
When should timing belt be changed
At how many miles should belt be changed.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi there and not sure if you got your question already answered or even still need it to be answered :) What I seem to remember is that the M10 318 and 318 ('84-'87) has a chain, the M40 318 and 316 ('88-'91 & not many in the US) has a belt.
E36 = M50 = timing chain. E30 = M20 =timing belt
Although you did not specify the year, model, and engine size, here are some general guidelines:
All the 4 cylinder BMW 3-series (318i, 320i) had a timing chain.
From 1984 to 1991, the 6 cyl (325 series) had a timing belt.
From 1992 and up, the 6 cyl (323, 325, 328, 335 series) had a timing chain.
If the BMW you are inquiring about should have a timing belt, BMW recommends to change it every 60,000 miles.
Hope this helps a little.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
+ Agreed
tarafından
it is my understanding since having a honda (belt) and moving to a jeep (chain) I have been told about this kind of issue. If you have a timing belt and the timing belt goes you can crack the head or bend a couple of valves, so depending on the mileage, better to do it if you are not sure its been done. Otherwise unless your crazy lucky a valve job + new valve stem seals while you there etc etc....I don't know about much about BMW's but i think it's the same kind of deal.
tarafından
the e30 320i had a timing belt and was a 6 cylinder m20 engine
tarafından
Yorum Ekle
Yanıtını ekle
lsaunders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 7,138
