Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
lagging controller after optic drive replacement?
Replaced optic drive successfully. Now the controller lags terribly. I've read that it's something wrong with a Bluetooth component on the motherboard. It's just weird because I barely touched the MB when I replaced the Drive. But any help is appreciated. Thanks
Bu iyi bir soru mu?
Puan 2
1 Yorum
Anyone? ....
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you have a problem with the WiFi antenna. First, check to make sure that the cable is plugged in under the power supply as it should be. If that's OK then you'll also want to check the large metal part that is on the disc drive. Check to make sure that the small wire is still soldered on to the large metal piece. I suspect that you may have forgotten to plug the cable back in under the power supply but it very well could be broken on that large metal piece in the front as well.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Austin Harris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 99
