Ana içeriğe geç
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
20 Soru Tümünü görüntüle
How to open FireTV Stick remote
Any creative ideas for how to open the fireTV Stick remote when you first get it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The two best options, as it turns out, are 1. Just pull really hard, or 2. Use a screwdriver to pry it open.
Here is a YouTube link that shows how:
https://www.youtube.com/watch?v=F__fFr7n...
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I went down the screwdriver route. Many thanks for the suggestion.
tarafından
Yorum Ekle
Simple once you know how. Hold BOTH ends of the remote, squeeze both ends gently and slide forwards
Puan 2
2 Yorum:
I agree. Sometimes, the new plastic pieces have micro texture edges resulting from the fresh cutting from the making of the pieces that give it a bit of a grip against each piece to where you will need to use something that allows you grip it better, like rubber gloves, or even a rubber band. I too had serious trouble opening it the very first time. I used latex gloves to open mine once, after that I could open it easily with bare hands. If you put a rubber band on your thumb and push it open that way, my bet is that it will open for you.
tarafından
Latex gloves worked - still have to push hard - Thanks
tarafından
Yorum Ekle
The person who designed this remote should be fired. Seriously.
Puan 1
1 Yorum:
Couldn't agree more. It's totally ridiculous for such a sophisticated device to be missing a little notch to open it easily.
tarafından
Yorum Ekle
I received the Amazon fire stick remote today, and took me quite a while to figure out the best way. Every time I press on the indent and move it up it opened a teeny weeny bit, and not any more. So finally, I pried it open a little and put in the batteries
Puan 0
1 Yorum:
Phew! Ridiculous! Took suggestion from YouTube & used rubber jar opener to gain traction while pushing down-still very tough!
tarafından
Yorum Ekle
Watched a video on YouTube with a very simple trick that works great. Turn the remote over so the little arrow is pointing up. Grip it firmly in your hand and hit the end firmly on a hard surface. If you do it right, the back cover pops right off. I got it off on the first try.
Puan 0
Yorum Ekle
Yanıtını ekle
Mitchel Szazynski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 78
Her zaman: 36,607
