Ana içeriğe geç
The Atari 2600 or Atari Video Computer System (VCS) is a video game console released in September 1977. The 2600 runs a MOS Technology 6507 CPU and uses ROM cartridges for storing games.
No power on my Atari 2600
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
badger9800 first you want to make sure that your power adapter works. Use a multimeter and check the output. you should get 9volts on that. If that works check the jack and make sure that it is properly working. Measure the voltage on the jack with the power supply plugged in. If you have power on the jack, you are having issues with the boards circuitry. POWER SUPPLY
The power supply is composed of a +5 voltage regulator, filter capacitors, and the power on/off switch. Unregulated DC is supplied to the board from the battery eliminator. A supply of +5 volts is routed through a filter circuit to the RF modulator. The motherboard also receives its power (+5 volts Vcc) from the switchboard via t h e same 12-conductor ribbon cable referenced above. So work from this and let us know what you get.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
badger9800 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 3,033
