Ana içeriğe geç
Canon EOS 500D olarak da bilinen Canon EOS Rebel T1i, 2009 yılında orta segment dijital tek lensli refleks fotoğraf makinesi olarak piyasaya sürülmüştür.
Canon 500D Hard Reset
T1i Canon-How to replace Canon 500D internal clock battery ou hard reset; 500D is not like 400D and battery is non accesible? In automatic like new but no access to manual control. Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
They say the battery isn't accessible but in fact that is incorrect. remove the main battery from the camera, then look in the slot the battery goes and you should see a little box thats been cut out but not fully, use a screwdriver to snap this lil tab out ( don't worry won't cause any harm ) and theres the little clock / date battery. next you will need a pick tool or something thin and pointy to remove the battery from its holder. to reinsert the battery is as simple as placing battery over the battery holder and push down and your all done.
Update (09/02/2016)
got a pic for you hope this helps
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
I can't find the little box. You have photo ? (T1i)
Thanks
tarafından
Good. I have, thanks
tarafından
ich weiss wo die systembaterie versteckt ist nur ich komme nicht ran?
muss ich da was rausbrechen?
tarafından
I took the battery out of a working 500d to test this, it didnt work. When I put the working battery back in the working camera, that now wont turn on? Can you damage these batteries by touching them?
tarafından
Hey mates, I took out the internal battery Of my Cannon Rebel T1i, The battery Says:
MS 614 SE / 9148
Unfortunelly I lost the Original battery (I’m an idiot I know) and now I can not find a place to buy it, I had found this:
‎MS614SE-FL28E‎
Seiko Instruments
BATT LITH 3V 3.4MAH COIN 6.8MM
https://www.digikey.com/ordering/shoppin...
Or
https://co.mouser.com/ProductDetail/Seik...
But I dont know If this battery would work, Can Anyone please help me, I’m desperate.
Thanks to all.
tarafından
Yorum Ekle
Hi,
My Rebel T1 / 500D / Kiss X3 is suddenly dead (after a blue light flashing near the WB button until I removed the main Battery).
I've tried everything:
change the main Battery, the SD Card, change and remove the optic, removed the main battery for a whole night, but nothing change, no power at all…
Do you think a dead button battery could cause this issue, or is it simply an electronic issue?
If anyone has a clue, I will grateful : )
Thierry
Puan 1
3 Yorum:
Hi, what was the solution? Attila
tarafından
Hi,
brought it to Canon and they charged me with an "Electric circuit replacement" (flat rate): 155€…
Now it works, but I didn't have any precise explanation about the issue.
tarafından
For the record, it wasn't cheap but 6 Years after it still works with no issue so far : )
If you wanna see some of my work I'm on Instagram (Monsieur Adragante) or on my book her:
https://adragante.bookfolio.fr/fr/
tarafından
Yorum Ekle
The battery Says:
MS 614 SE - 9148
‎MS614SE-FL28E‎
Seiko Instruments
'''https://www.digikey.com/ordering/shoppin...
Or
'''https://co.mouser.com/ProductDetail/Seik...
Thanks to all.
Puan 0
1 Yorum:
MS614SE the battery model(seiko)
tarafından
Yorum Ekle
Yanıtını ekle
Roger Gag sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 7,950
