Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
What removes polarizer glue?
Hello I am just getting into screen refurbishment having purchased a few bits of kit
I am struggling with what is best to remove the adhesive under the polarizer (iPhone 6) So far when I use my heat plate to separate the LCD from glass I either completely remove the polarizer or partial do which means I have to manually take it off.
What I am struggling with is the remains of the adhesive under it. It seems like solid plastic
So my question is what best removes this? I cannot afford to spend 1hr per screen removing this.
Many thanks
John
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thanks for your response. Worked a treat.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I carefully apply a little wd40 to all but the very edges of the screen (careful it doesn't go into backlight)
Leave to act for a minute
Use a thin shaving style razor blade ( the really thin double sided ones) to scrape it off working from bottom to top only and in lines.
Clean the blade after each stroke
Only use one blade side per screen. It'll be too blunt after one .
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Interesting, but my question is: Why remove the polarizer in the first place and not just leave it on?
tarafından
They get scratched during the process of removing the glue. Using OCA shows these marks unlike LOCA
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 3,307
