Ana içeriğe geç
Katot Işınlı Tüp (CRT) Teknolojisi kullanır. Eski monitörler ve televizyonlar uzun yıllar boyunca bu görüntüleme türünü kullandı. Üzerinde çalışmak çok tehlikelidir, ancak küçük onarımlar yapmak mümkündür.
Black lines on screen
There are black lines on the top and bottom of the screen. There are not any potentiometers on the back so I can't change thr picture manually. What can I do to make it look like 4:3 again. This is a crt tv by the way. Thank you in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
eraywhite what make and model is this TV? What have you tried? Post some images of what you see with your question. For that, use this guide Mevcut bir soruya görsel ekleme It will allow us to see what you see.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You don't specify what make or model. On the older crts the gross adjustments are inside the monitor the outside controls are for fine tuning.
DANGER! DANGER!
To adjust the gross setting it involves removing the back cover and working near the high voltage flyback with the power on.
ONLY USE PLASTIC OR INSULATED TOOLS
(I ALSO WEAR RUBBER GLOVES)
CRTs can KILL....
There should be three plastic potentiometers with slots cut into them for a small flatblade.
On really old CRTs they also used small magnets attached to the sides of the picture tube as well.
Adjust the monitor slowly. If possible have someone else watch the picture while you adjust so you can insure not touching a live board.
You life is not worth an inch of black screen.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
eraywhite sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,408
