Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
Multiple Problems with the iPhone 4s
This will probably sound very confusing, and probably never heard of, but i'll try my best to explain.
I came home one night, and my phone didn't automatically connect me to wifi, so I went to my settings and went to connect to wifi, but it was acting a bit slow and would freeze for a second or so. Once I did connect, it only lasted about 30 seconds before I was disconnected. I tried again and it did the same thing, connect for 30 seconds than kicked me off. When I went back to re-connect, it couldnt find any networks to connect to, usually when this happens i turn off the wifi and turn it back on, but this time it never turned back on, and I couldn't do anything besides open up my assistive touch and play with those options, the home and power button didnt do anything in the assistive touch.
I force shut down my phone using the assistive touch power button and the actual home button, and it goes to an apple screen, and stays there until i open the back and uplug the battery and put it back in. Once i do that it still does the same thing over and over, no fix whatsoever nor could I find any solutions online.
Does anyone think they can help me? or is it just time to get a new phone.
Bu iyi bir soru mu?
Puan 0
2 Yorum
I think the system software has gone bad? Have you tried restoring or upgrading it?
tarafından
I've tried upgrading it, still doing it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you tried a soft reset on the phone? Hold down the home button and the power button. Normally this will take care of a lot of issues. Also, the less space you have on your phone, the glitchier it will be.
If all else fails, plug it into iTunes and see if it can be repaired or restore if need be.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
kangaroofilms sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 206
