iPhone 4 stuck on connect to iTunes screen
Hi, I recently repaired an old iPhone of mine intending to recover data from it. I broke it in an accident 3-4 years ago, and just now decided it was time to replace the LCD/digitizer and battery. I succeeded in repairing it, but now it tells me to connect to iTunes so that I can access it, with the USB cable and iTunes logo on the screen. Easy enough, right? Except that when I plugged it into my PC, iTunes told me that I would be unable to access it unless I put in the password. I remember the password, but the problem is, I am unable to put it in because the screen is stuck at the USB cable and iTunes logo, and will only allow me to make emergency calls. Is there any way around this? Thank you for your time.
Bu iyi bir soru mu?
I forgot to mention I would like to avoid restoration, as the whole reason I repaired it is to recover my data.
marquis tarafından
Can you update it? Or is it already the latest version supported by the iPhone 4? Have you tried holding the home button and sleep/wake button until the apple comes up?
Josiah tarafından
It's stuck on the activation screen. Are you able to update the phone via iTunes while it is in recovery mode?
Ben tarafından
