Ana içeriğe geç
2.3L 4cyl or 3.0L V6, 6th Generation
426 Soru Tümünü görüntüle
Remove rear seat pillar to access child lock
Rear driver side door is jammed and child safety lock is engaged. I need to remove the "bolster" or "pillar" adjacent to the door. I removed the lower bolt but can't budge the two clips. I can't even budge the interior door panel without doing so. I know I can do this myself!
Thanks,
Pretty and pretty capable woman with no pink tools
I did it!!!
With the help of YouTube videos, I was able to remove the inner door panel and rear seats obstructing this part of the project.
Locating an existing hole, I 1/2" paddle bit drilled it through and beyond the outer panel. Now I could access the offending child safety lock. Using a bent shish-ka-bob skewer, I fished and fished with no luck. Walked away for an hour.
Regaining my confidence, I tried again. No luck. So I very carefully tried with a finger, mindful of the freshly cut metal. Pop! The child lock is located just above that pre-drilled hole... door opened from the inside. Still not from the outside, but that's for another day.
If I can do it, so can you!!!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Yeahhhhhh, u go girl.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Laura Boehmke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 153
