Ana içeriğe geç
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Soru Tümünü görüntüle
Cant turn on WiFi?
About two days ago I was walking on a somewhat tilted deck in a marina, and long story short I slipped into the water, sadly with my HTC One m9 in my pocket. I was in stomach high water for about ten seconds before I climbed out, phone still in pocket. I immediately turned off my phone even though it worked fine for the second I was looking at it. I proceeded to take it out of its case and dry it thoroughly , and let it sit in the warm sun for about two hours. Later It wouldn't turn on, and when charged the device would turn on and stay on, but the screen would flicker and go to black. After leaving it sitting for one night, I faced the same results. At this point I Decided to take advice from a friend who has been in this situation many times before, and let it sit in an oven running at 115° F for a couple hours, to remove any major water in the phone. I came back, let it cool down, plugged it in, and let it charge for about ten minutes, and then turned it on, and to my joy it worked! Although it may have been slow and somewhat unresponsive for the first minutes using it, it has now become smooth as ever with everything BUT one of the most crucial aspects of a phone, Wi-Fi. I am able to flawlessly use my LTE coverage, yet whenever I attempt to enable Wi-Fi it attempts to for about a minute then says ERROR where the icon is. After hours of use of the phone and its regular functions, I still get the same result, and it leads me to believe that somehow the built in Wi-Fi card was damaged while the rest of the phone survived. If there is any way to attempt to fix this, it would be much appreciated, as I am currently on vacation and cannot get a new phone through the warranty I have until I am home, and I would rather not burn up all of my data using my phone. Thanks and sorry for the long read.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem lies with the water damage already being done on the Wi-Fi component area on the logic board. You would either need to clean the affected water damaged spots that have water damage marks (white spots, green spots, water residue, burn marks) with 99% isopropyl alcohol but even though I wouldn't recommend doing this yourself as there are heaps of ribbon cables going from the daughter board, screen to the main logic board which sits right on top of the phone battery.
In short you should send it in to a reputable mobile phone repair shop for them to check the water damage done to the phone and see if they can fix the problem.
The logic board and other affected parts need to be cleaned well or you may have an increased risk of the phone running into more problems in the future (cleaning it reduces it significantly).
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Vic Fal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,248
