Insufficient storage message is not disappearing from screen?
Insufficient storage message is not disappearing from screen, what should I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Dear friend,
I had read your issue ,
i can understand that the message appeared due to insufficient storage space,
goto setting>storage look what you have in memory, if it shows only little mb of "available" space you can see it
you also can see a view of what data stored in memory
example image is uploaded here
you can see in it
Available 3.73GB
Apps (app data & media) 1.57 GB
etc..
if available memory is less delete what data have more that one and increase available space
after that just restart it
if have any of doubt just upload screen shot then ask
good luck my friend
Bu yanıt yardımcı oldu mu?
But the message is continuously pop up in the screen, so I can't do any thing in my phone. Even I can't unlock my phone.
then switch off phone and remove battery, after 30 minutes re-insert battery then start it then follow what i said before, good luck
I've tried everything, but its still there. Do you know any alternative method to reset the phone??
you can easily reset phone
by following the below
but be careful (data will lost)
1. turn off device
2. remove battery and re insert
3.hold volume down and power button (vol + and ON/OFF )
then you can you had entered other screen
reset in that you can see
many option
you select wipe data/ factory reset
the select yes option
and wait till reboot
good luck my friend
thank you....
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 62
