Ana içeriğe geç
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Bricked Phone help me bring it back Alive
please guys anyone help me !
what can i do to my phone i was facing some problems with it and my friend tried and failed by loading a wrong boot on it so the phone is worthless right now it's not starting or giving any respond when i connect it to my laptop and i didn't get the chance to use it i only used it for a month .
Please any suggestions or ideas would be appreciated
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
i'm using a converter because in my country we don't have the proper cable
tarafından
Hi, how is everyone doing? I also bricked my device. It's also not able to go into fastboot. It's a moto G X1032, and android 5.1 was installed on it before flashing. I tried using file from this link https://forum.xda-developers.com/moto-g/... to revive it but it failed. please help, thanks.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
You likely just need to reflash the factory images. Just boot into fastboot by holding volume down and power, and flash the factory image from here: https://developers.google.com/android/ne...
If your phone shows QHSUSB_BULK in device manager, it is much more complicated. It seems that there is no unbrick method for the 5X currently if you are stuck in that mode.
Bu yanıt yardımcı oldu mu?
Puan 0
10 Yorum:
i pressed volume down and the power button put it didn't do anything
tarafından
Plug the phone into the computer, what do you see in device manager?
tarafından
it says unknown USB Device
tarafından
Can we get a screenshot? Also what cable are you using.
tarafından
tarafından
5 tane daha yorum göster
Yorum Ekle
So, what was the final chapter? Could you turn it on? I have this issue: sending sparse 'system' (524289 KB)... FAILED (too many links)
Puan 0
1 Yorum:
try a different usb port
tarafından
Yorum Ekle
Yanıtını ekle
Mostafa Heikal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 5,469
