Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Bu iyi bir soru mu?
Hey Everyone,
Bu iyi bir soru mu?
This guide would be the easiest, if you don't want to solder it
Sega Dreamcast Controller Port Replacement
This guide would use a little more work, but you could individually change out one controller port
Also found this on eBay
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,477
3 Yorum
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
Ben Eccles tarafından
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
thunderblrd tarafından
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
