Ana içeriğe geç
Asus Zenbook UX301LA, 13,3 inç IPS ekrana sahip bir Ultrabook bilgisayardır. Intel'in Ultrabook serisinin bir parçası olarak Kasım 2013'te piyasaya sürülmüştür.
Fan constantly running at max speed
I have a problem with an ASUS Zenbook UX301LA where 10-20 minutes after I boot up the fan will start running at maximum speed regardless of temperature/CPU usage.
If I just start up and leave it idle the fan will kick in after a short time, the temperature sensors show core temp hovering around 32-38°C (90-100°F) and the CPU usage not rising above 2-5%. Once the fan is stuck on max even after a couple of hours idle it won't come down.
I've updated all drivers in device manager, updated the BIOS, downgraded the BIOS but to no effect (I have had other problems with the BIOS since upgrading to Windows 10, but I didn't have this problem for the first 4 months or so after the upgrade). I also tried to build this laptop fan control tool but didn't have any luck on Windows 10 (I know pretty much nothing about Windows system programming).
Any suggestions much appreciated :) It's not a huge problem but it would be nice to find a fix. The fact that the temperature sensors are showing sensible values makes me think it's not just a damaged/unplugged sensor.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hey there,
in my laptop, the fans get really dusty and it seems that it makes them run more frequently. I am assuming the corresponding temperature goes up along with it (I have never checked), but it might be worth a try to clean all the fans. Make sure to fix them while doing it, so that the turning fan cannot induce any currents in the laptop while it is off.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the same issue, the only solution i could find in order not to compromise the battery life is to create a new battery mode.
Just choose a maximum CPU rate and yes it slows the computer but it's not a problem for most usage. You should choose 40%, that's the best compromise between performance, noise and battery life. I can even reach 10h usage on one charge with low brightness.
If you find any other solution in order to tell the system to keep the heat without turning on the fan or just at a precise temperature let me know.
Here's a screen capture (in french) but you could find it easily.
http://i68.tinypic.com/11scev6.png
Puan 0
Yorum Ekle
Hi,
this is how to silence your laptop.
1. Download Notebook Fan Control : https://github.com/hirschmann/nbfc/relea...
2. Install it and launch it
3. In "Selected config" menu, select profile for Asus Zenbook UX301LA.
4. Set "Fan control service status" to Enabled.
5. Right click on bottom right icon for Settings > Check Start with Windows
NB. During summer, you may have to Disable Notebook fan control for a correct heat evacuation.
If you experience weird laptop behaviour, disable it too.
Another important thing is to flash latest Bios available for your laptop.
Enjoy ;-)
Puan 0
Yorum Ekle
Yanıtını ekle
Avy Linus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 7,668
