Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Soru Tümünü görüntüle
Why does iPhone not power on?
Hi , I bought iPhone with bad battery. The phone does not charge and when is connected to a PC nothing happens . Hard reset is also not possible due to damaged home button.
I tried to replace the battery but without any changes.
Thanks for the advice .
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would replace the dock port, since you said home button doesn't work it is likely that the dock port is damaged and causing the phone not to charge. Also try booting with the camera flex removed.
Bu yanıt yardımcı oldu mu?
Puan 0
9 Yorum:
I tried to replace the battery with a new one and new battery Would should have some energy , right ?
tarafından
Does the battery have a charge? (Check with a multimeter) If it does then try to power on with only the screen power flex and battery, no dock port
tarafından
Thanks for your advice , I tried to use old battery and the phone is switched on , but after 4-5 minutes always restarts . With the new battery will not turn on .
tarafından
That indicates a charging problem, replace the dock connector first, they are cheap, and then see if it gets fixed
tarafından
But the phone with old battery is charging and recognizing by iTunes.
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
vasekopacalek2 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 127
