Ana içeriğe geç
Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
872 Soru Tümünü görüntüle
Is the RPM of the hard drive that important?
I am trying to decide which hard drive upgrade to get for my future new Mac Mini model A1347. I would like to get as much storage as possible, of course. I see that I can get 500GB at 7200 RPM or 640GB at 5400 RPM.
Will I notice that much difference in speed between these two drives? I don't work with huge files, but I do often have several applications open at a time and switch between them. I plan to max out the RAM at 8GB, eventually.
Bu iyi bir soru mu?
Puan 2
1 Yorum
This question was migrated from http://meta.ifixit.com/.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's an excellent article with test results on the speed bump you get on a 7200 RPM drive verses a 5400 RPM drive: http://www.mactech.com/articles/mactech/...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Good article +
tarafından
Thanks for the link - it is nice to have quantify-able data on the difference.
tarafından
Yorum Ekle
I would opt for the 7200RPM drive, just find one with as much storage capacity as possible. I recently upgraded to a 7200RPM from 5400, and I noticed a difference in speed as far as opening apps and such. Not a big difference, but noticeable.
Puan 2
2 Yorum:
tarafından
Thanks for taking a stand and making the suggestion. 7200RPM it is!
tarafından
Yorum Ekle
You may be able to quantify your options a bit, assuming you have a mac already.
Set your dock to not auto-hide and put Activity Monitor (from Applications -> Utilities)in it. Right click on the icon in the dock and choose Dock Icon / Show Disk Activity. Now open the programs you think you'd use and do what you expect you would do in them, keeping an eye on that icon. Now as I understand it OS X keeps closed programs in memory for reuse if you open them up again until it fills up the existing ram, then it starts recycling (witness the dot under your Safari / iTunes after you close them) so you could expect that after the initial program load your 8 Gigs of ram will work to minimize the work your drive has to do.
On a somewhat related note, it's not uncommon to kit out a performance / gaming rig with a small HDD or even SSD for the OS then add in a large capacity (slow) internal or external drive for your music, movies and other programs where speed doesn't matter much but having them available does.
Puan 1
1 Yorum:
Great idea. The whole "virtual memory" aspect of the OS really makes it difficult to gather your own data on this sort of thing. And I appreciate the strategy suggestion for what should be fast and what can be slow.
tarafından
Yorum Ekle
There would be a fairly noticeable difference, however you have to decide if the cost is worth it to you, it's noticeable, but not that significant.
Puan 0
Yorum Ekle
Yanıtını ekle
Ross Heitkamp sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 10,738
