Coffee grounds in cup while brewing
Grounds coming out of K cup while brewing
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I periodically insert a safety pin into the top needle....then I choose and run the "hot water" function....you should notice grounds in your cup. Repeat the safety pin procedure until the water is void of grounds. Others may use a straightened paper clip. Be careful.
BTW: I often do this during the brewing process....the brewing stops when you lift the lid.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 104
