Ana içeriğe geç
Repair guides and support for netbooks manufactured by Compaq.
18 Soru Tümünü görüntüle
My computer Loss the power after 2 min when charger is pluggged
Computer is working fine when it is in on battery, but when I connect my charger my laptop is loss power(off directly) after 2 to 5 minutes.
Already i check my adapter it is OK, with other adapter same problem occur.
Also i check my power supply of my house no problem was there, It is happen in other home also.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello,
probably you will have a bad connection in the laptop. Try to replace the DC jack. or try with an other..
If you know enough about electronics, you can try to measure out the PCB connecting your dc tot the main board. I had a same issue to an older model of acer. it was a bad connection in the PCB.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Anup Pasari sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 70
