Ana içeriğe geç
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Soru Tümünü görüntüle
Dropped phone will not turn on
Hello, the other day i dropped my LG G2 VS980. The case protected the screen from cracking, but it wont turn on. If I plug it into the wall, a charging light comes on and if i touch the power button it start continuously vibrating, but the screen stays black.
if i plug it into the computer, the logo will flash then the screen goes black and the charging light goes on and it starts vibrating. if its not charging it wont do anything if i touch any of the buttons.
I opened it up and everything looked pretty normal. Any advice?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
I drop my phone lg2 it turn on then it goes off again sometime I charge it the red or the green thing come on sometime it don't
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey there. It definitely sounds like the LCD is busted from the fall.
You can try opening it up and disconnecting the screen cable and reconnecting to see if that works, but if not, I would recommend replacing it. The replacement guide linked here will bring you to where you can do this, but also if you need to put on a new screen as well.
I don't know what carrier you are using, but this link is basically the part that you need. Here on iFixit, they only have the full assembly for the Sprint model. You can always check Amazon or Ebay if that's not what you're using though.
If you don't want to rush into replacing the screen and you have data backed up, here are a few steps you can take to reset the phone: (source)
Hardware factory reset:
-Take your phone and turn it off – just press power button and select “power off”.
Wait while your device is shutting down.
-Then, press volume down button and power button together until the LG logo appears on the screen.
-When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
-Once you do that, on your LG G2 the factory reset menu will be displayed.
-Press power button in order to agree and wait while the hard reset is being completed.
Software factory reset:
If you can use your phone then you can perform the hard reset in an easier way.
-All you have to do is to tap on the “menu” icon.
-Go to “settings”.
-Select “general” and pick “backup and factory reset”.
-Then choose “factory reset”, agree and complete the hard reset operation.
If all of these options do not work, it could be board damage, but it definitely is worth it to open the phone to check everything out.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
But the logo will flash when i plug the phone into my computer, doesn't that mean that the LCD isn't entirely broken?
tarafından
I'm going to edit some things to my answer. It'll have a few more options for you.
tarafından
Yorum Ekle
How can I fix my LG 2 phone that won't turn on but when I turn it on it goes on a little bit then turn off I plug it it show the green and red then sometime it doesn't turn on at all how should I fix this how should I fix my LG 2?
Puan 0
Yorum Ekle
my LGg2 phone is not turn on
Puan 0
Yorum Ekle
Yanıtını ekle
Windorabug 93 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 3,205
