Ana içeriğe geç
The third generation of the DJI Phantom series released in April 2015.
20 Soru Tümünü görüntüle
Controller battery won't charge
The battery in the controller won't accept a charge. When I plug in the charger I can turn the controller on, but it won't charge, even when left plugged in for hours. Also, when plugged in and turned on, the red light next to the four white lights is illuminated. I'm guessing the battery is bad. How do I replace the battery?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
6 Yorum
I have the exact same problem. I have only used it once!!
tarafından
I'm in the same boat however, mine will flash the one led for a few moments and then will stop.
tarafından
Same problem with my phantom 4 RC. Send to repair, happen again after 1 month.
tarafından
Just wanting to know PS, XBox, Nintendo Wii etc... and when it is plugged in, does the controller work normally when it is plugged in? Can you play if controller is plugged in?
tarafından
Yes. Does this mean it is simply a bad battery?
tarafından
1 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have just had the exact same problem with my Phantom 3 Pro controller.
After speaking with DJI I solved the problem, and I have put the instructions on YouTube:
https://www.youtube.com/watch?v=P60RY47G...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I've seen this happening with a Phantom 3 standard before. For me, it wasn't the battery or the cable, but the actual USB connector on the controller. It seemed like they didn't do a great job in the factory soldering the USB connector to the printed circuit board that it sits on. Once you've ruled out that your issue isn't a bad USB cable/charger, you may want to consider this. If you look at this picture, you'll see that the USB port is attached to a little circuit board that is wired to the rest of the controller. I was able to repair the connection between the USB connector and that board with a fine-tip soldering iron, if you're handy with a soldering iron you may want to try the same. If you aren't experienced with a soldeirng iron, I was able to find a replacement part on eBay (but nowhere else so order soon!).
Good luck!
Puan 3
1 Yorum:
Very helpful of you sir for sharing. Mich thanks and long live.
I do guess that dji should do a recall since a lot of us are affected. I have only flown 5 times and this happened to me.
tarafından
Yorum Ekle
I found that you have to push the charging cable in VERY far. Much farther than you think. Mine wouldn't charge either - then I realized it was NOT in far enough. If you're 100% sure it's all the way in and isn't charging then I can't help you with this 'simple' fix. Good Luck.
Puan 0
Yorum Ekle
Hi, I have a repair service for this fault at http://dronerepair.ab-repair.co.uk/start...
It is not normally the battery but a faulty component on the main board inside. It costs £52.50 to repair
Puan 0
1 Yorum:
I can't open the link what is the part that your talking about.
tarafından
Yorum Ekle
Yanıtını ekle
Charlie Gaines sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 22,744
