Ana içeriğe geç
LG'nin benzersiz, kaydırmalı batarya tasarımına ve birden fazla donanım genişletme seçeneğini destekleyen çıkarılabilir giriş/çıkış modülüne sahip amiral gemisi akıllı telefonu. Nisan 2016'da piyasaya sürüldü.
half the screen has dark lines
Half of my screen has dark lines going through the left side of the screen and it will not respond to my touch. The battery is also overheating each time I put it to charge. What do I need to do to fix both of these issues?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum:
Is the screen cracked? Waterdamage? Repaired before?
tarafından Paylaş
Hey Cristal, I would defiantly like a little more details, how did it get like this? Did it drop or has the device been exposed to water?
tarafından Paylaş
Yorum Ekle
4 Cevap
Filtre ölçütü:
The screen is not cracked and has never been repaired before. About one month ago water did get to it but it did nothing to my phone. My now ex boyfriend had slammed my phone on the ground 2 to 3 times.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Whoever had slammed your phone has caused the problem. Get a new screen.
Update (02/02/2017)
Is it cracked? How long have you been using it? If you have been using it for a long time, try getting a new battery. If it's cracked then you should get a new screen. If it's not cracked then open it and if there isnt a wire connecting to the screen, look at a teardown to see what goes where.
Puan 0
Yorum Ekle
I have a similar issue and saw that with a dif. model several people had the same problem as well. The prevailing sentiment is that it is a defective battery and can be fixed by replacing said battery.
Puan 0
Yorum Ekle
I replaced the battery, but the screen still has black lines and won’t repond to touch.
Puan 0
Yorum Ekle
Yanıtını ekle
cristal rosales sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 29
Her zaman: 2,481
