Stick remote not clickable
The remote won't let me enter my pin and then if I click the select button it tells me my remote is not clickable - any suggestions?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
So... I just found out that holding the left, right , and menu buttons simultaneously for 5 seconds will reset the remote. Good luck!!
Bu yanıt yardımcı oldu mu?
Holding The menu button alone fixed my problem
Thank you so much cuz my son did something to mine and it was going crazy and I was just flipping out this. Good used it in that work thank you
Hold the menu button down on the remote. It will switch back to standard remote.
This is the only thing that worked thank you so much my remote now works and isn’t saying control not clickable
What does it mean when it says remote not clickable
Worked!!! Thank You!
I need help because it is not working my firestick remote
I need help because my firestick remote is not working I have tried everything that it does what do I do?!
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 14,551
2 Yorum
I am having the same issue. I guess I sat on the remote and a combination of buttons was pressed activating the voice commands (this is not a voice command remote!!).
George tarafından Paylaş
Thanks George that helped me my son dropped his remote in the tank and I had to take the batteries out put the remote in some rice over night then shake out the rest of the water out put it back in the box of rice for two hours. Then once I put new batteries in the voice control thing came on and it kept staying device not clickable until I held down all the buttons at one time. Then saw the green box's on the TV was gone and it started to work. Thanks so much
blackqueen0420046 tarafından Paylaş
