Determining loose capacitors after water damage
I have a water damaged iPhone 6 plus logic board. I have shown below the NAND area of the logic board, and I have circled and labeled 5 capacitors that are burnt/loose. Does anybody know exactly which capacitors these are so I can buy replacement ones especially number 1? If anybody could tell me exactly what to look up at mouser.com that would be amazing.
If anybody can tell me what any of these capacitors are I would greatly appreciate it. Especially number 1 because it is so badly burnt. My iPhone will not start up/show in iTunes and I believe this is the reason why. I already have a micro-solderer who will put these on if I can figure out what capacitors they are.
Thank you for any help I can get,
Joe
Update (08/05/2016)
Hello Old Turkey!! Thank you for replying, I really appreciate it! The number you are asking for is 820-3675 and the model is an Iphone 6 Plus. Not an Iphone 6s Plus. I have added three pictures for clarity on location on the board. I updated which parts I have "circled" and I only need three parts identified. Number 1 which I believe is a resistor, and numbers 2&3 which I believe are capacitors. Please let me know if there is anything else I should add in order to help. Thank you again, and I really appreciate it!!!
Bu iyi bir soru mu?
6 Yorum
If it helps I believe that 2 and 5 are the same size (T5301), and 1 and 4 are the same size, but I don't know what 1 and 4 are. Nor do I know what 3 is, but I believe 2 and 5 are the same size as most of the capacitors on the logic board. Please let me know if this is correct, and any information on 1 would be really really appreciated.
Thank you,
Joe
Joseph Waltemire tarafından
If anybody has any information on even the cap values of these parts, even that would extremely helpful.
I don't know if anybody has been looking, or if anybody has seen this post, but I have an update. I've figured out what those capacitors are, and I believe I have the correct ones ordered on Digikey.com. Once they arrive I will have my professional Micro-Solderer take the bad ones off and put the old ones on and I will post an update on whether or not there's any success with starting my Iphone or if it is detected in iTunes.
@joeshmoe what is the 820-XXX number on your board or what exact model is it out of? 6S+? Take anohter picture but this time zoom out so we can see the location of the components in relation to the board.
oldturkey03 tarafından
@oldturkey03 I have posted an answer to my own question for you. It's not an answer, it's a couple more pictures added for clarity in order to be better able to help. Please take a look, and let me know if there is any other information I should add!!! Thank you for the help!
1 tane daha yorum göster
