Ana içeriğe geç
Asus ZenFone 2 (ZE551ML), ASUS tarafından Mart 2015'te piyasaya sürülen bir Android akıllı telefondur.
Camera failed to launch
I am getting this error on my zenfone 2, is there anyway to know if this is due to a hardware problem or a software problem? Any place where i can buy the camera replacement?
My country doesn't have Asus service
Actualización (25/07/16)
I have disarmed and note that the front camera was incorrectly connected , connect it again but the error persists, something I can try?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
you can use the calculator test benchmark for see if is a hardware problem.
open the asus calculator and insert .12345+=
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
It says Something wrong with Main Camera Capture Test!
is it hardware right¿
tarafından Paylaş
looks like, I have same problem.
also front camera is not working or only back camera ?
tarafından Paylaş
Yorum Ekle
Sir , I did so (.12345+=) . Flash is working & showing test passed but cemara showing black ..
Kindly advise me to solve the back cemara problem
Prasad , Hyderabad
Puan 1
Yorum Ekle
everytime i test the camera features the SMMI TEST shuts down. I have problem with the camera not working since last week. Everytime I try to open the camera, it shuts down by itself and tells me to restart the cellphone and when I do it the problem persists. Can anyone help me with this problem? Thank you.
Puan 0
Yorum Ekle
Try doing a battery pull..
  1. Turn off the phone.
  2. Remove the battery.
  3. Wait about 5 to 10 minutes.
  4. Put back the battery.
  5. Turn the phone on.
Hope this helps.
Puan 0
Yorum Ekle
I got the same priblem now and im browsing the answer how can i fix it.
Puan 0
Yorum Ekle
my phone was dropped and i found out 1 of the small component was missing, soldered the missing component as a joint (make it short jumper) after that camera starts working.
just look carefully at all the components should be something loose or missing …
Puan 0
Yorum Ekle
Hi. I have the same problem and same situation (my country does not have an Asus support centre). All I can tell you for now is that buying a new camera will not solve the issue. i found one at a good price on AliExpress and had it shipped. Waited for the longest time for it to get here, only to find out that the issue is not with the camera itself, but with the logic card. And having no support centre nearby, fixing the logic card will not be happening anytime soon.
Sorry to be the bearer of bad news.
Puan 0
Yorum Ekle
Asus have fixed the problem by ota update on October 26th
You just fallow the link to update your camera into a next level
https://youtu.be/UOYooxdVwBQ
Follow the
https://g.co/payinvite/a9cy00
Puan 0
2 Yorum:
Follow the link for info of Asus camera problem
You can mail me on ghosh.sumanfot001@gmail.com
tarafından Paylaş
All camera problem will solve
See that tutorial video
tarafından Paylaş
Yorum Ekle
This is what worked for me. I have no idea what steps are essential.
The camera on my zenfone was dead. Every diagnostic said it was dead.
I did a factory reboot. The camera was still dead.
A couple weeks later, I rebooted the phone. I laid the phone flat on a surface so that the lens would only see dark.
I fired up the camera app. Let it sit for a minute. Went from the rear-facing to the front-facing setting a couple times. I picked the camera up, and for a few days it has been working fine.
Puan 0
Yorum Ekle
Yanıtını ekle
Kinzo Edge sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 19,916
