Ana içeriğe geç
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Soru Tümünü görüntüle
New AC compressor now overheating. Help!
I have a 96 Camry V6 3.0 I bought for 400 dollars. But the car has ran great and I have taken care of it. 223,000 miles on the car. I just put in a new AC compressor and now I'm overheating. I know the AC draws alot of power but what can I change now to stop overheating? Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Probably not an answer but make sure the belt is at proper tension. Make sure the water pump pulley if fully engaged and turning. See if there is a difference when the ac is on, and when its not on.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The tension is good, the fans are ruining strong, I did a coolant flush a month ago. I looked about an hour ago and I was really low on coolant. I filled her up then drive her for an hour and she kept a good temp. I know I filled her full when I did the flush. It was over 100 degrees today. Maybe just to hot for an old car but I changed the compressor to have ac on days like today. Thank you for the reply.
tarafından
No problem. I just assumed your coolant level was correct. Good to see you keeping and older car going.
tarafından
Yorum Ekle
Yanıtını ekle
BRANDON S RHEA sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 209
