Why is my front facing camera not working?
Whenever I go to take a picture the camera shows a black screen. I've tried factory resetting the device with no avail. Do I need to replace the camera or is it unfix-able?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First be sure that the lenses view isn't obstructed by any foreign objects, i.e. fingerprints, dust, etc. Also be sure that the lighting is adequate. If this doesn't help you may need get inside the tablet. When you take it apart be sure that the camera's cable is plugged in all the way; otherwise, replace the camera.
Bu yanıt yardımcı oldu mu?
As a last before replacing the camera module, try to do a factory reset. Sometimes, more often than not, there may be a software glitch that will cause the camera module drivers to operate improperly.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 143
