Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
FH error cannot be isolated
get FH error as machine fills. checked flow switch, pressure switch and pump all seem ok.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The repair was the replacement of the input water meter. Although it looked good a replacement solved the error
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
@ivegot2beme as you probably already know the error code can come up with water supply valves that are not turned on, the inlet screens are clogged and the pump strainer/filter is clogged. It can also be caused by a bad drain pump motor. I suggest that you download the service instructions from the bottom of this page and run the diagnostic cycle. Then let us know what you found. Unplugging the machine and leaving it unplugged for 15 minutes will reset it.
Puan 2
Yorum Ekle
Yanıtını ekle
larry dalessandro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 153
