Ana içeriğe geç
Announced - 2014, November The Samsung Galaxy Core Prime (G360, G361) is powered by 1.3GHz quad-core processor, and it comes with 1GB of RAM. The phone packs 8GB of internal storage that can be expanded up to 64GB via a microSD card.
67 Soru Tümünü görüntüle
My phone does not turn on
My phone read T-Mobile update available when I tried to update the phone it says update failed at 92% now the phone won't turn on. When I press the power button it vibrates and shows the Samsung Galaxy Core Prime powered by android screen and is stuck there.
I am located in the Caribbean at the moment.
Can you help me with this problem I have only had the phone for about 6 months
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would try to clear the cache partition in recovery mode. To do this you first need to boot the phone in recovery mode.
Press the Power, Home, and Volume up buttons at the same time.
Release all key when Android or Samsung logo appear then you will see Android System Recovery.
Navigate with the volume keys, and select with the power button.
Navigate to wipe cache partition, and select it.
Wait for that to finish, then reboot your phone.
Hope that helps :)
If it doesn't work though, i would do a factory reset using the same method, unless anyone else has a better answer. (The factory reset will erase ALL personal data from your phone. So it should be a last ditch effort.)
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I have the same problem too, but it didn't work. Although my updates didn't fail, but my phone ran out of battery and shutdown and i cant turn it back on again, have any ideas?
tarafından
i just bought the same phone today it is just turning on and off continuously
please help
tarafından
Yorum Ekle
If also not solved your problem try to change volume keys
Puan 0
Yorum Ekle
Yanıtını ekle
candyluvcall411 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 2,045
