Ana içeriğe geç
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
service manual canon eos 70d
Hi
I need the service manual
Do you sell the manual?
Best regards
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I wasn’t able to find the eos 70d service manual but did find the eos 60d service manual instead and because these cameras are similar might help:
https://elektrotanya.com/canon_eos-d60_s...
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Please send me the link for the Canon EOS 70D service manual if you get it. Thanks
tarafından
Thanks :D it's a beginning
tarafından
EOS 60D and EOS D60 are NOT the same camera. D60 Manual won't work for 60D-70D. Canon cameras can indeed be confusing.
tarafından
Yorum Ekle
Hi,
You can find the manual at http://media.the-digital-picture.com/Own....
I hope this helps :)
Kind Regards,
Aaron
Puan 1
2 Yorum:
Is it a service manual or a user manual? I do need a service manual that shows how to open the camera internal guts.
tarafından
I need the service manual:)
tarafından
Yorum Ekle
I need full service manual of 70d canon because my camera not getting on ant went inside camera n may be bord got short
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
Primero comprobar que los pulsadores de tapa tarjetero y trampilla portabateria se liberan bien . Después Hay un IC de 6 patillas 3+3 con denominación identificacion M04 en la placa base,junto al conector de presión largo alargado que suele ser la avería habitual con los problemas de encendido power ON .
Por otro lado el modelo EOS 70D presenta fallos en procesador cuando hay recalentamiento por exposiciones muy prolongadas o por utilizar el modo video cuando la temperatura ambiente es alta , entonces,solo un cambio de PCB es efectivo el problema es que si no enciende el modulo original no se pueden salvar ajustes de un módulo a otro y que los módulos pcb Main son muy costosos.
Puan 0
1 Yorum:
En aliexpress muchos distribuidores ofrecen IC 3+3 (M04 ) para,venta,por separado del módulo, al ser un componente SMT necesitas un dessoldador de aire caliente para retirarlo y cinta aluminizada o kapton para proteger el conector cercano de un exceso de temperatura que lo pudiera deformar.
tarafından
Yorum Ekle
Yanıtını ekle
eduardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 75
Her zaman: 4,898
