HELP: Cold Room Temperature Issue
GE Profile Harmony Dryer
GE Profile Harmony electric dryer: Here's a tricky one for you. My dryer won't power on when it's cold outside, nor will it power on in the summer when I have the house cooled with the air conditioner.
I am able to keep the control panel powered on: I have to set it on DELAY START so that the control display panel won't turn off. As long as the digital panel stays lit, it's fine, and it dries perfectly!
If I forget to set the delay function, I have to heat the room around the dryer's control panel, unplug the dryer for twenty minutes, replug it, wait five minutes, then, if the control panel is warm enough, it will power on.
It wasn't always like this. For the first five years, this never happened -- no matter how cold it got outside.
I've read several other posts online about the same issue, but no one has the answer on what to replace in order to fix it. I'm so tired of having to remember to reset the delay feature or to waste so much electricity using a ceramic heater to heat the panel! I don't want a new dryer-- I just want to replace the faulty part! Can you be our hero?
Bu iyi bir soru mu?
2 Yorum
I also have this problem wirh my kenmore dryer.
williamandkandyce tarafından Paylaş
Hi @williamandkandyce,
What is the model number of the dryer?
jayeff tarafından Paylaş
