Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone not turning out/ not being recognised in iTunes
Hi,
I have an iPhone 6 which I bought not turning on. The screen is cracked. I have opened it up and both water sensors are still white so doesn't look like water damage. I have changed the screen and battery but it is not switching on. It is also not being recognised in iTunes. The motherboard isn't getting hot or overheating. Any ideas?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Logic board/ charging flex/ battery are the possible faulty parts.
If you can, try with other parts, if you can't, buying parts are not a wise idea.
Better to take it to a repair store.
tarafından
Check if it is drawing any current from the usb cable with a multimeter or a specialized charge tester.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Do a Apple hard reset put and hold the power button and home button at the same time for 10-20seconds
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
T K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 52
