Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Phone does not respond after screen replacement
So I just replaced the screen of an iPhone 5s. During the repair everything went good, no weird things. I did everything step by step as I always do. After closing the phone I connected it to a power cable, nothing happened. No charging sign nothing. It also doesn't turns on. So I opened the phone again and checkt everything, it all looks good. Closed the phone again and as espected, nothing happened.
I need help, I don't know what could cause this problem.
Update (08/16/2016)
Found it, the battery is dead. Thank you all!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
I'm guessing it worked before and you already tried old / new screens? This is one of those times where I would plug iPhone to computer and check up if iTunes / computer gets a response from the phone.
tarafından
Well if I look back, when I got the phone, the phone didn't turned on at all. So I guess it's the battery? I'm going to check it with my multimeter.
tarafından
Yes, I was already downloading iTunes to check.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Battery/charging flex/logic board are the possible faulty parts.
If the screen is faulty and you connect it to a mac, iTunes should start. If it doesn't happen, then one or more of the internal parts are faulty.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Stijn Helmonds sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 39
