Ana içeriğe geç
2010 yılında piyasaya sürülen orijinal PSP 300x modelinin revizyonudur. Onarımı aynı derecede kolaydır.
Psp 300x Backlight Fuse
Hi Guys!
I have my old PSP 3001, I drop it on the floor. Still turn On and Off, but with out image...
I replacentment the LCD, but still not working.
So I found out that is a BACKLIGHT FUSE,
Please some one tell me
"WHERE IS THE BACKLIGHT FUSE"?
I am tired to find out and get no result!
Thanks all guys who read and help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
There is only a backlight fuse. There is no screen fuse. There is either a problem with the screen, or one of the components on the motherboard. Probably the IC that is in charge of video.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Try checking component ic4104. That's the backlight driver and is located in the 11,C quadrant of side A on a TA-085 v1 board. The part number is TB62752BFUG. Test each connected capacitor to ground in continuity mode with a basic multimeter for a short. If one or more of the capacitors are shorted remove those and check the pads where the capacitors were. If there's still a short on both pads where the capacitors were then put back the original ones. Odds are if there's a short to ground but doesn't go away when you remove the capacitors then TB62752BFUG needs to be replaced.
PSP 2k Schematics (~95% 3k)
https://gamingdoc.org/technical-document...
TB62752BFUG Datasheet
https://www.mouser.com/datasheet/2/408/T...
Puan 0
Yorum Ekle
Yanıtını ekle
Josemar Pereira sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 1,222
