Ana içeriğe geç
Stickies application will not open.
When I click on the stickies icon in the doc or in the applications folder no stickies will appear. I get the stickies bar across the top but no stickies.
Sandy
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
On the menu bar at the top navigate to Window and confirm that there are any active stickies. There should be a list of all open stickies there, click one to pull it to the front. If there are no stickies listed, then all Stickies have been closed. Make a new sticky by going File>New (+N).
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
It's working
if you see the menu bar change, and the throbber in the the Dock. Also check under Apple icon->Force Quit if it's frozen it will be noted.
• To close this note, click the close button.
• To collapse this note, double click the title bar.
• Your current notes appear when you open Stickies
If you have no new or current notes there's nothing to show.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Puan 2
1 Yorum:
Thank you so much. You rock!
tarafından
Yorum Ekle
I had a similar issue with my computer showing the Stickies app being open, yet the Stickies were not visible.
  • Make sure Stickies is open
  • Menu Bar -> Window -> Expand
Hope this helps at least one person.
Puan 0
Yorum Ekle
guys real problem solver for disappeared stickies, check this link out , https://www.howtoisolve.com/sticky-notes...
Puan 0
Yorum Ekle
Yanıtını ekle
Sandy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 14,304
