Ana içeriğe geç
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Soru Tümünü görüntüle
Sleep awake failure and restarts. Is it related to power supply?
Hi everyone,
When my iMac goes sleep it won't wake up, instead it will restart.
I have tested it with different OS's, HD's and RAM modules. I have also replaced the CMOS battery, still no luck.
Now I am going to buy a power supply and give that a try. What would you say?
Does anyone knows if power supply could be the source of the problem or nothing got to do with it.
Thanks for the help in advance!
P.S. - Everything else works way it should.
Update (09/16/2016)
Hi
Finally I have replaced the power board but unfortunately it didnt fix the issue :(
I guess its related to logic board .
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Have you tried Resetting the SMC? Follow this Apple T/N: Reset the System Management Controller (SMC) on your Mac I would start there.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi Dan.
Yes I have reseted the SMC but it didnt help.
Thanks
tarafından
Yorum Ekle
Power supplies have a second supply for standby. It is low power but keeps certain circuits alive during sleep mode. If that supply stopped working but the primary supply was ok you might get the effect you are seeing. Before replacing it, I would unplug the AC for one minute and then reconnect and try start up and sleep again. If the standby supply has become locked off due to some glitch, the unplugging the AC will allow it to reset. Worth a quick try.
Puan 0
3 Yorum:
Hi Whole Witt.
I have unplugged the AC several times didnt change anything.
I guess replacing the power board is my only option .
I just want to find out whats role of the power board in Sleep Awake cycle before I spend any money .
Thanks
tarafından
I suspect a power issue. If the supply standby power is not working at all it could give you this problem. No guarantee but that is worth a try. If you find the solution, please post it here for others to see.
tarafından
I will go for power supply and post the result here .
Thanks again.
tarafından
Yorum Ekle
Yanıtını ekle
Kip sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 165
