Ana içeriğe geç
HTC One (kod adı M7), HTC'nin 2013 yılı amiral gemisi telefonudur. Kusursuz tasarlanmış yekpare alüminyum gövdeye, ön tarafta 2 adet büyük hoparlöre ve 4.7 inç 1080p ekrana sahiptir.
Phone is going into a boot loop after replacing parts?
My phone goes into a boot-loop the workaround is going removing the flex cable?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
I replaced the daughter board (cos volume up was broken), New screen with front housing, battery, charge port and back cover. So am I using an incompatible part I noticed the daughter board number was different to the original but this wasn't specified on the suppliers website. When I turn it on it goes into a boot loop, when I plug charger in the charge bolt icon come on and goes to boot loop the way I made it work was removing the flex cable which made it boot and then i have to plug it back in to make the power button work and SIM reader. I even tried putting the old board back and ldc but still the same? Only the charge port is left to test back.
tarafından
I put my old parts back so I'm just going to refund it.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Please provide more detail to your question. It would be helpful to know what parts you replaced, which repair guides were followed, what issues you may have encountered during reassembly, etc.
Without more info, I'd say you're stuck with tearing down the phone again and double-checking all connections are seated correctly, that no wires have been pinched or shorted against the case or other internal parts.
Good luck,
_rs
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
tarafından
"[I'm] using an incompatible part"
I think you answered your own question.
Are you able to get a hold of the correct part? That would seem the easiest solution to me.
tarafından
I have the old part which I connected same problem so I'm not sure what it is.
tarafından
@webuxr yes I tried it, turned it on without connecting just in case then connected flex cable and did a reboot and it worked until I tried to open the camera and it keep crashing and it froze so I forced it to shut down and went into a bootloop tried reflashing too but nothing. I was watching a reassemble video and in the comments someone had got a boot loop and turns out the camera copper was causing a short? So I don't if it is that because I have noticed the camera has a rubber thing to maybe hold it against the frame so I don't know what to do?
tarafından
Well some sort of tape like kapton tape (yellow tape) or even double sided tape that isn't too thick is a good candidate to place over the missing grey foam / rubber thing?
tarafından
1 tane daha yorum göster
Yorum Ekle
Just gave a refund instead forget it.
Puan 0
Yorum Ekle
Yanıtını ekle
saf98 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 371
