Ana içeriğe geç
Repair and support for the third generation of the Flip portable speaker by JBL.
70 Soru Tümünü görüntüle
Why does my JBL Flip 3 not produce sound?
I just bought a JBL Flip 3 2 days ago, i didn't get warranty because i couldn't afford it. i have charged it twice and haven't gotten it wet, or handled it improperly. i woke up this morning and went to play some music through it and there was a rattling sound whenever i played anything from it. so i turned it off and then back on, and not it doesnt produce any sound whatsoever.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
I have this problem too, I think the problem was the cable I used to charge, I used a cable that was not original, try to unload completely, leave the battery to zero, then charge again, remember to use the original cable . If it works, leave your comment here, thanks.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
i will try this did it work for you?
tarafından
Bagaimana hasilnya?
tarafından
Les cuento mi experiencia, el mio funcionaba perfectamente, hasta que la bateria dejo de cargar y solo funcionaba enchufado, lo abri, le quite la bateria que estaba inflada y habia roto la carcaza de tanta presion, eso ayudo a desarmarlo ya que tiene un flex que da toda la vuelta y es imposible sacar. Cuestion que cuando lo enchufaba sin bateria no tenia sonido, la conexion de la bateria es necesaria para que funcione. Volvi a conectar la bateria vieja y sonaba asi que solo queda comprar el epuesto. Espero les sirva
tarafından
Yorum Ekle
there is a bottom on the inside on the motherboard labeled ir5 and when loose doesn’t play music you have a figure out a way to tighten it back on
Puan 0
Yorum Ekle
Yanıtını ekle
Cocoa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 1,309
