Ana içeriğe geç
Bluetooth üzerinden çalışan akıllı fitness saati, Mart 2016'da piyasaya sürüldü. Model: FB502SBUL
Could I replace the battery?
My Fitbit Blaze battery only lasts 10-12 hours. Is it possible to change the battery? If so where can I find a replacement battery? I know it uses a 167 mAh Lithium Ion Battery. I'm not having any luck finding one. The battery has never worked right. Fitbit sent me a replacement pebble. I'd still like to attempt to fix this one.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
2 Yorum
Has anyone found any battery replacement valid for Blaze?
tarafından
I replaced my Blaze battery with this one from Amazon:
Fitbit Blaze Smartwatch Battery (Li-Pol, 3.7V, 120mAh) Replacement for Fitbit Blaze Smartwatch Battery
It's been about 2 months now and I am very happy. A charge lasts for about 3 days now.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here’s where to get the battery:
Fitbit Blaze Battery
Here’s how to install it:
Fitbit Blaze Pil Değişimi
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V). Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You should disassembly it and then check for it's battery and then you can buy a new replacement .
Puan 0
5 Yorum:
@acnologia how do you disassemble it and where can one get a new battery?
tarafından
There's a video on YouTube how to disassemble. The where to get the battery is the real question I've looked haven't had luck. The battery is a 167 mAh lithium ion battery. Good luck let me know if you find one.
tarafından
@oldturkey03 It's easy ,just use YouTube ,i have seen guides that do it really fast.
tarafından
Anybody know the dimensions of the battery? There are a lot of 3.7v rechargeable batteries on AliExpress
tarafından
The battery for the Fitbit Blaze is 3.2mm X 18mm X 30mm. 3.7V, If it's more than about 31 or 32 mm long, the new battery won't fit, so be careful.
tarafından
Yorum Ekle
Yanıtını ekle
Tracy Kirkpatrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 10,323
