Ana içeriğe geç
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Can I modify Thunderbolt display to replace mindisplay with a USB-C?
Hi all,
I have a new Macbook but also a 2012 Thunderbolt display. The Macbook only has a USB-C port and I was wondering if anyone has come across people replacing the Thunderbolt display's Mini Display cable with a USB-C one.
Is this even possible?
Any Mini Display-to-USB-C adaptors were very quickly (and suspiciously...) discontinued shortly after they were released in 2015.
Any advice or info would be much appreciated.
Henry
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
Do be clear here you want to use the Thunderbolt display with your MacBook, correct?
tarafından
At present there is no adapter for the USB-C to Thunderbolt. and i do not believe there is any other way of doing it :(
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly, there is no means to connect a new MacBook which has a USB-C port to a Thunderbolt display presently. Hopefully by the end of next month we might be offered an answer from Apple ;-}
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Just to keep this updated, there is now an adapter available from Apple - https://www.apple.com/uk/shop/product/MM...
tarafından
Yorum Ekle
This is supposed to work, I have not tried it
https://www.nonda.co/products/hub-mini-u...
Puan 0
2 Yorum:
Yep! I thought this hub would do it, sorry nope!
It's only DisplayPort compatible! Not Thunderbolt.
Note the compatibility line at the bottom 'Apple Cinema display only with Mini Display Port' no listing of the newer Thunderbolt display. I know I was hoping too ;-{
tarafından
Yorum Ekle
Yanıtını ekle
Henry Kirby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,898
