Ana içeriğe geç
Golf Mk4 ilk olarak Ağustos 1997'de tanıtıldı, bunu Ağustos 1998'de notchback versiyonu (VW Bora veya Kuzey Amerika'da tekrar VW Jetta) ve Mart 1999'da yeni Golf Variant (station wagon) izledi.
Broken cigarette lighter - Fuse problem?
So the light around the rim comes on when I turn the lights on, but it doesnt seem to work. Tried plugging my sat nav in and got nothing, although it works in other cars. What do I need to do and how? Please help me
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes
it could be a fuse. Look in fuse box for blown one - often inside the cover of the box it tells which fuse is for what.
If the new fuse just blows out then there's a short in the unit (or wires leading to the unit). If you find the short it may be repairable, or you may need to replace the unit.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
The light in the rim and the lighter itself are two different circurits. As said before look for a blown fuse.
tarafından
To add to the info above: Power outlet is #26 (20amp) and the Cigarette lighter is #24 (25amp)
tarafından
Only have 22 fuses, none marked 12v outlet, car does not have cig. Lighter.
Light around outlet does not light up,
2002 G L X.
Unplugged from back no power, which fuse should it be?
tarafından
Yorum Ekle
Hello I have a problem in tidying up not working for four golf 4
Puan 0
Yorum Ekle
Yanıtını ekle
Krystyna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 8,769
