Ana içeriğe geç
Sony Cyber-shot DSC-W5 5.1 Megapixel
10 Soru Tümünü görüntüle
Why is my telescoping lense stuck
i droped the camera and now the lense does not move out to take photos
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You dropped the camera
causing the lens to jump or deform the guides that move the lens.
If under warranty see if it can be replaced... if not see if its worth fixing.
Generally these sorts of things are not DIY repairs
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
what happened when you dropped the camera is that the lens was open and has offset. what you need to do is force the lens to center and it will return to its chassis location and work. (happened to me)
Puan 1
1 Yorum:
Thank you. Fixed my problem!
tarafından
Yorum Ekle
A stuck lens happened to me twice - I dropped it twice!
After the first time I found a Sony service depot that told me it wasn't worth repairing, a $200 camera at the time (mine is a DSC-S600). I wasn't about to toss a Christmas gift from my kids!
I don't remember how I found them but twice now I've had the stuck lens fixed by "Home Electronics & Comm" at the Yorkgate Mall, northwest corner at Finch & Jane in Toronto, (416)665-5126. They repaired it for under $75 each time! Ask for Gohar.
Puan 0
Yorum Ekle
How do you force the lens to centre?
Puan 0
2 Yorum:
Simon, this is an old question and not to many people look in here. Your question appears like an answer. If you need some help with your camera, click on the link on the right side of this page "Ask a question" and give as much detail as possible, like what camera it is, what happened to it and what you have tried to fix it. Good Luck.
tarafından
I did not drop but my lens got stuck Make sure batteries are good press on button and ok button at the same time and that fixed the problem
tarafından
Yorum Ekle
Yanıtını ekle
ml91401 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 20
Her zaman: 4,689
