Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
4 Yorum:
there could be several reasons to why it doesn't charge but the most common are bad batteries, water damage, broken charging port. all three of these are recommended techs only to fix so i'd take it to my local repair agent and get them to have a look. good luck
Hortman tarafından
Peppe, what do you mean by this "with the connector does not happen charging"?
oldturkey03 tarafından
The USB port is ok
He did not take water
Peppe tarafından
the battery if the load with bench power supply accepts the charge
the problem is that you do not see the charging status
Peppe tarafından
