Ana içeriğe geç
Brother HL-5240, Kasım 2005'te piyasaya sürülen bir ofis lazer yazıcısıdır.
The printer prints blank paper
The toner is new but nothing prints on the paper. It feeds like it should but spits out blank paper.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
Penny,
Silly question, but did you remove the plastic protector strip when you installed the new toner?
tarafından Paylaş
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here are the steps to fix the brother printer printing completely blank pages issue.
1.     First of all, you should restart the devices, and then give a print command.
2.     Let’s cancel all print command, and then visit the printer properties, let’s see if your printer is showing available in the queue or not?
3.     Most of the time, people are getting the blank page from their brother printer due to the ink cartridge issue, so you need to assure that your printer has enough ink to print a text on the paper, if it doesn’t have enough ink, you may replace the ink cartridge as well.
4.     Apart from this, you may have the ink cartridge issue due to the installation issue, so you should uninstall the ink cartridge and reinstall the cartridge again. now give a new command, let’s see if your printer is allowing you to print a document or not?
5.     Sometimes, you may be getting the blank pages as an output due to the driver issue, whenever your printer is not printing the documents, you should take out the driver from your pc, and install a new driver on your pc.
6.     After using the above steps, if your printer is not allowing you to print anything, I will suggest you to factory restore your printer, and then reconfigure it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
LOL of-course a silly question @djmetzle but surely that the first question to come to mind .. then probably resitting the cartridge...
but highly sure it is that plastic protector either not removed or partly broken inside as mentioned by @djmetzle
Puan 0
Yorum Ekle
https://youtu.be/IeUgSDXL5ms
Might be helpful
Michael
Puan 0
Yorum Ekle
If your brother printer is currently printing blank pages. here are the steps to fix it easily.
  1. First of all, make sure the cartridge/ toner is installed correctly. If not, you need to remove it from the printer and reinsert it.
  2. Check the skip blank page feature from the brother settings.
# Clean up the printer properly.
  1. Reinstall the printer driver.
  2. Service the printer.
Once you will make these changes, the brother printer will start working fine. in case, if you are still dealing with some other issues. please feel free to visit: why is my brother printer printing blank pages?
Puan 0
Yorum Ekle
Did you use the correct number of toner ink in the cartridge? There are many numbers in ink and each printer supports only a fixed number or type of ink. If you will change the type of ink it won't print.
Puan 0
Yorum Ekle
toner cartridge is not install
Why this, I have even buy a new cartridge
Puan 0
Yorum Ekle
Yanıtını ekle
Penny NIceluy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 39
Her zaman: 14,910
