Ana içeriğe geç
A rotary tool by Dremel with different speed settings and attachment options.
Opening the case of a Dremel Model 8200
I need help opening the case of my dremel 8200 to replace the motor. I can unscrew the screws and remove the collar at the front, but there is a metal tab at the rear that I can't see how to get out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hey mate, this guide will help you out. Dremel 8200 Disassembly
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi, Jeff. To open the case, you will need to unscrew the 5 torx screws and take apart the metallic hanging. There are two internal boards (sliding potentiometer plus SCR), which are replaced as a unit. Mine device has one of the boards blowed up after some intense use (overheating) and I have bought the replacement at Tool Parts (Omaha-NE) and since there it worked fine (now paying attention to not overheat it). May be it would be interesting to measure the motor (DC) before declaring it guilty. Hope this helps you. If you need pictures I am available to send them (through email).
Puan 0
Yorum Ekle
Yanıtını ekle
Jeff Sparksworthy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 539
