Ana içeriğe geç
Repair information for the Beats Studio 2.0 wired headphones. Originally released in 2013. Model number: BT OV STU BLK.
Speaker crackles and pops
So this has nothing to do with the 3.5mm cable but the speaker itselft. My left speaker crackles and pops when i move around. Very annoying to listen to music and walk since music on left side stop and crackles. I went to a repair shop and they said if they try any harder they could break the whole thing! Don't know what to do now. Any suggestions? Would local apple shops be able to fix this? Or do i have to send it off for it to be repaired?
Bu iyi bir soru mu?
Puan 5
3 Yorum
Anybody manage to get a handle on this? I have the same problem
tarafından
YO YO YO, I FINALLY SOLVED THIS , I KNOW YOU PROBABLY GOT ANOTHER PAIR OF HEADPHONES BUT FOR THOSE OF YOU WITH THIS PROBLEM
Its the way the ear cup folds , NOT THE BAND ! the ear cup is what I’m referring to.
Put a hair tie in the middle behind the earcup and the stem ! IT WORKS I SWEAR ON MY LIFE !!
tarafından
omfg omg it works! What? I tested it out and yes, my right one was at a different position than my left one!!
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Joshua a bad cable/connections could cause speaker clarity issues, if your positive not the cable, probably best to contact apple support or at least check out their trouble shooting guide.
Check the attached link,instruction and guides, Good luck.
https://ca.beatsbydre.com/en/support/tro...
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
i'm definitely sure its not the cable as i tried 3 different types of working cables. Thanks for the suggestion. I'll try your link
tarafından
Had the same problem. Even opened up the shell and checked the wiring inside. Seemed not to be the problem. After closing everything up, I found out that when you put pressure on the shell, pushing it away from the headband, the crackling stops. So I wrapped a peace of rope (5 mm. thick) twice around the shell. Downside: the shell can't move anymore. Upside: the crackling is gone.
tarafından
hello i have a problem quite similar but not exactly, my beats studio 2.0 works perfectly fine ...WITH EVERYOTHER DEVICES THEN MY PHONE! i own a gakaxy s9+ and everytime i try to listen to something i hear kind of a buzzing / crakling sound in my left ear. not sure really what to do with it.... i had this beats for more than 5 years and nothing but now with that phone i cannot even hear a whatsapp message without this crakling sound. any suggestion?
tarafından
Yorum Ekle
I've had this problem too when listening while my phone was charging. I unplugged the lightning cable and the popping went away.
Puan 0
Yorum Ekle
Your coil within the speaker driver may have popped out. If that's the case you can get it repaired. We sell the part and service if you need help reach out.
https://www.joesge.com/pages/repair-serv...
Puan 0
Yorum Ekle
Yanıtını ekle
Joshua Serban sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 61
Her zaman: 18,223
