Dead Acer Aspire ZG5?
Hey guys.. I have an Acer Aspire ZG5, that I got a year ago, running Windows 7. It worked perfectly, like a charm. But I forgot about it, and and put it in a locker. I opened it up recently, and found the computer. I picked the charger, plugged it into the wall and on the machine. I pressed the power button, but the battery light turned on, and faintly turned off. Sometimes, all of the lights turn on, and suddenly turn off. I tried to do a hard reset (no battery, just charger). Nothing. I tried to do the reverse (only battery). No response. I don't know what to do, is it because of the dust that maybe inside it?
I hope that I get it working fast...
Greetings,
~Gum
Bu iyi bir soru mu?
6 Yorum
Hi Try letting the charger charge the battery for 3-4 hours before attempting to switch it on and see what happens. A dead flat battery need to be given a chance to revive.
jayeff tarafından
I will try. It needs to rest a bit.
Gum Skyloard tarafından
@jayeff
most laptops can run with 0 battery or even no battery, they can get power directly from the adapter.
Try taking out the battery completely and then try to turn it on again
echow2001 tarafından
Hi @ethanchow00
Thanks for that.
jayeff tarafından
@ethanchow00
I tried, no success.
1 tane daha yorum göster
