Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Keyboard and TrackPad not working...
Keyboard and trackpad for MacBook A1181 is not working in its original machine... I have tested this keyboard and trackpad by installing into another MacBook(same model) and its work well and good...power button is working as well....
what seems to be the problem??? hope you can help me figure out the problem... thankss
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
did you check if another topcase works on your macbook? because if both don't but they work on a different macbook, your board might be cooked.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
is there a way to fix the logic board?
tarafından
Look in the socket for blockage
tarafından
Yorum Ekle
En Yararlı Yanıt
Recently I refurbished a Macbook A1181 (version 4.1 , the one @2.4Ghz) and I had the same issue.
When I finished the repair and mounted the keyboard and trackpad back on, as well as the battery, I realized they where not responsive, despite the power button still worked.
I read in a forum there was an issue with this particular model and the ground level, making that both the keyboard and the trackpad don't work.
What I did was sticking a tiny little piece of a plastic sheet between the metal case and a little gold V-shaped connector that is spotted in the left side of the battery connector board (if you watch it from the pins side), to avoid contact between them. This worked for me.
Hope this helps.
Puan 1
1 Yorum:
can u please share more details ,because i face the same problem......
tarafından
Yorum Ekle
Yanıtını ekle
Cled Tayamen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,238
