Ana içeriğe geç
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Xbox one S - Loud fan noise
Hi,
I´m recently bought a 2tb Xbox One S and it´s fan sound like something is hitting the blades. Any guess about how to fix it?
Bu iyi bir soru mu?
Puan 10
6 Yorum
Hi,
I´m glade that my "experience" could help you. It´s really a shame MS quality control.
tarafından
Hey the same is happening to me too, it's past the warranty and I can't return it so which type of fan should I use in replacing it
tarafından
Austin, search for a PWM fan. I used a Corsair one, working better than The original.
There several youtube guides to change The fan, its easy enough to do at home, just take care and not hurry things.
tarafından
Is there a illustration to show one how to perform this fan replacement? , iIfound a Cougar Vortex PWM 800-1500RPM fan
tarafından
I don´t any illustration, but is working fine to me.
tarafından
1 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Yan,
It´s really simple to change the bearing, you can remove the fan without have to remove the heatsink. The fan is almost the same, but it dont fit well, because the height of the one s. I suggest you change the fan to a custom one, like corsair or another pc fan, it´s really simple, look for guides in Youtube, i got better results changing the fan instead of the bearings.
Hope it could help you.
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
I saw on youtube peoples saying that after changing the fan with an custom one they have problems with overheating. Is that true?
tarafından
I don´t have any problem. It´s important that the fan is a PWM, so it can change the speed of the fan when is necessary.
tarafından
And when you are gaming you are sure that your fan increases speed? And your custom fan is focused for air flow or static pressure?
Thanks!
tarafından
I hear it´s getting faster (and louder), so yes.
tarafından
Thanks for the info! Where did you get the replacement bearings, are they a particular type?
tarafından
2 tane daha yorum göster
Yorum Ekle
Has anything fallen into the fan? Anything unusual happen to the unit? (Like getting knocked over, hit, etc.) At this point, I would recommend sending it in on warranty. Since it was only just released, you should be able to get it fixed for free under warranty, and you won't risk damaging it more opening it up.
Puan 0
Yorum Ekle
Hi Ben Eccles,
I kind of fixed the fan noise. Last night I open the entire console and removed the fan, I discovered that the sound was coming from 2 crap bearing´s inside the fan, changed them and said goodbye for the noise, at least until now.
Tks for the help.
P.S: Sorry about my poor english, I´m from Brasil and I´m a little rusty.
Puan 0
1 Yorum:
No worries! Glad I could help!
tarafından
Yorum Ekle
Hi ricardo
I got the same problem, is it easy to change the bearing? (can i dissemble the fan without removing all the heatsink?)
I was thinking to change the fan myself but i don't know if the Xbox One fan is compatible with the One S fan.
Thx
Puan 0
Yorum Ekle
Thx for your help, i have changed the fan, i've used a PWM 120 mm fan.
Now the Xbox is quiet, the hard drive is louder than the fan :)
It's a shame for Microsoft quality control, a lot of people got this problem (and some are thinking the buzzing noise is normal)
Puan 0
12 Yorum:
tarafından
No overheating for me with an Akasa AK-FN064 fan
tarafından
And when you are gaming the fan is increasing the speed?
tarafından
and how did you solve with the conector? what are the pins for controling fan speed?
tarafından
For me it was a little trick, but tested the cable until discover. If you dont set the cable in the right way, it will be set in full speed all the time, even if its on sleep mode.
tarafından
7 tane daha yorum göster
Yorum Ekle
Hello!
What typ of fans are you guys using? Or rather from what manufacture? Want to be ready to change it if i get the same problem when i recieve my One S.
Puan 0
1 Yorum:
I´m using a PWM fan from corsair. But if you receive yours Xbox One S with the problem, send it back and exchange for a new one.
tarafından
Yorum Ekle
Yanıtını ekle
ricardogranjaadv sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 34,746
